IMPORTANT. Forum to be archived in several phases. You can no longer submit new questions - but can only answer existing threads until Oct 17th 2016. Please read this message for details
Mechanical Desktop (Read Only)
MDT_2006_installation_error
1 REPLY 1
211 Views, 1 Reply
Group,
I'll try again!!!!
Just installed MDT 2006, then tried to install SP1a. Received this message.
I down loaded SP1a from AutoDesk, then tried installing the service pack.
The file I down load: Mdt2006_AIP10_swl_SP1a.exe
What is the next step???
[img src="@115772"]
1 REPLY 1
mjroha
I'm not sure if you've resolved your issue, but I've got a question for you. From your post, it shows that you've downloaded the service pack for Inventor Professional 10/MDT 2006 Locked version. Is this correct? If you've got Inventor Series, then it's a different service pack. Also there is a Locked and Unlocked version of each. I normally work with Inventor Pro and the first time I had to work with Series, I downloaded the Pro service pack and got the same error.
Mike
