If you have more than 3 GB of RAM on your machine, try the 3 GB switch as detailed in the following link: http://usa.autodesk.com/getdoc/id=TS1071001
Hope this helps
Sridhar
So any clue as to why it would be happening on Windows7 64bit with 4 GB of Ram?
Can you let me know what version of Autodesk application are you using?
Thanks.
We are actually using Revit Archtiectural Suite 2011, and the problem happens mostly in Autocad on multiple machines. (I have 7 licenses). This is the only forum where I have been able to find an intelligent response to what seems to be a fairly widespread problem. I posted the problem on my subscription site and they told to re-install Windows 7 and Autocad. No joke.
At this point of time, I can think of increasing the virtual memory of the machine. You may increase it to 2 to 3 times of your RAM size. Find attached image.
Hope this helps
We have been getting this error on our standalone Civil 3d licenses since 2009. We are currently running 2011 on a Win 7 (sp 1) workstation 64 bit app with 12 gig ram. Our prior machines were running XP pro with 4 gigs of memory. I do not think this problem is a memory issue or a vertical specifc problem.
Any other AUTODESK help??
Hi @sibuprasad73,
Welcome to the Autodesk Community.
If you haven't already done so, I recommend that you contact our Registration & Activation team, so that they can check your license. If they confirm your license is valid and still eligible for use, but the issue persists, then you can start a new thread on the Installation & Licensing forum and provide as many details as possible about your problem (without posting confidential information, such as your serial number and e-mail address). Our I&L experts will help you.
