IMPORTANT. Forum to be archived in several phases. You can no longer submit new questions - but can only answer existing threads until Oct 17th 2016. Please read this message for details
Mechanical Desktop (Read Only)
License is invalid error. HELP
9 REPLIES 9
Message 1 of 10
13088 Views, 9 Replies
Once and a while I get a "Your license is invalid. Please contact your local authorized Autocad Dealer". It also comes up with "Fatal Error: This Product has not been properly activated on this system" at the same time. Most of the time it's fine but every once and a while this error comes up and shuts down Mechanical Desktop. I have tried to see if it comes up at a certain time or day and that is not the case. It is at random. I do have a valid licence. Please Help.
9 REPLIES 9
Message 2 of 10
Sridhar-Autodesk
I suspect the cause of this error is your operating system is running out of available memory (2 GB for 32 bit OS) and is shutting the application down. The reason you are seeing the license error is because the link to the application's activation files on your hard drive is being disconnected.
If you have more than 3 GB of RAM on your machine, try the 3 GB switch as detailed in the following link: http://usa.autodesk.com/getdoc/id=TS1071001
Hope this helps
Sridhar
Sridhar Subramani
Senior Product Owner
Message 3 of 10
HawkAIA
in reply to: Sridhar-Autodesk
So any clue as to why it would be happening on Windows7 64bit with 4 GB of Ram?
Message 4 of 10
Sridhar-Autodesk
in reply to: HawkAIA
Can you let me know what version of Autodesk application are you using?
Thanks.
Sridhar Subramani
Message 5 of 10
HawkAIA
We are actually using Revit Archtiectural Suite 2011, and the problem happens mostly in Autocad on multiple machines. (I have 7 licenses).  This is the only forum where I have been able to find an intelligent response to what seems to be a fairly widespread problem.  I posted the problem on my subscription site and they told to re-install Windows 7 and Autocad. No joke.
Message 6 of 10
Sridhar-Autodesk
At this point of time, I can think of increasing the virtual memory of the machine.   You may increase it to 2 to 3 times of your RAM size. Find attached image.
Hope this helps
Sridhar Subramani
Message 7 of 10
lonesa
We have been getting this error on our standalone Civil 3d licenses since 2009.  We are currently running 2011 on a Win 7  (sp 1) workstation 64 bit app with 12 gig ram.  Our prior machines were running XP pro with 4 gigs of memory.  I do not think this problem is a memory issue or a vertical specifc problem.
Any other AUTODESK help??
Message 8 of 10
The link is not working
Message 9 of 10
sibuprasad73
try every solution but nothing can solve my problem
Message 10 of 10
Hi @sibuprasad73,
Welcome to the Autodesk Community.
If you haven't already done so, I recommend that you contact our Registration & Activation team, so that they can check your license. If they confirm your license is valid and still eligible for use, but the issue persists, then you can start a new thread on the Installation & Licensing forum and provide as many details as possible about your problem (without posting confidential information, such as your serial number and e-mail address). Our I&L experts will help you.
Simona Golisciano
