IMPORTANT. Forum to be archived in several phases. You can no longer submit new questions - but can only answer existing threads until Oct 17th 2016. Please read this message for details
Mechanical Desktop (Read Only)
Layer Color Keeps Reverting
5 REPLIES 5
1312 Views, 5 Replies
Interesting problem: In AutoCAD Mechanical 2014, I created a new layer. I set the color for magenta. Then as I was working, I noticed the drawing (which I did not create) had too much magenta on many layers, so I changed the color of the new layer I just created to color 23 (brownish). However, as I'm working on the drawing, the color will revert to magenta all by itself! This has happened several times; and I can't see what causes it. There's no pattern in my work that seems to trigger the reversion. Smiley Surprised
Anyone?
5 REPLIES 5
pendean
Is this a layer name totally unique to you, like JLNims1234, or is this a layer name that MECH 2014 can create and use itself through other functions and processes?
in reply to: pendean
Thank you for the response.  The layer name is unique to the drawing.  The name is actually "Tire_Platform".
Bump!  No solution as of yet.
Anyone?
pendean
There is nothing in the OOTB program that change a user created layer's color or any other property.
So either someone is doing that, or you have an add-on or predefined tool doing it for you. Sadly only you can discover that.
A test: put a small X in the layer name, at the front, and see if the problem suddenly stops or something in your program complains (or worse, it creates the original name as a new layer).
"A test: put a small X in the layer name, at the front, and see if the problem suddenly stops or something in your program complains"
I did place a small x in the layer name; and the problem seems to have gone away.  Not sure if this is an actual solution, because it was just a non-automated layer in the first place.  But it seems to be working, so I'll take it!  Smiley Happy
Thanks!
