Announcements
IMPORTANT. Forum to be archived in several phases. You can no longer submit new questions - but can only answer existing threads until Oct 17th 2016. Please read this message for details
Mechanical Desktop (Read Only)
Install of SP2 on 2007 still shows Hotfix2 installed only
5 REPLIES 5
275 Views, 5 Replies
I just installed SP2 with just Hotfix2 installed and when doing a AMVER I still get Mechanical Desktop(R) 2007 Hotfix2, not SP2. Restarted and everything.
Here is AMVERALL (short):
ACME 11.2.0.7
MCADATTS 11.2.0.7
Attributes 11.2.0.7
GREFACAD 11.2.0.7
CIT 11.2.0.7
MCADCOM 11.2.0.7
MCADAPI 11.2.0.7
MPP 0.0
AutoSurf 11.2.0.7
GREFSURF 11.2.0.7
GrefAd 11.2.0.7
GREFSURF 11.2.0.7
GREFAM 11.2.0.7
GREFDM 11.2.0.7
GREFSYS 11.2.0.7
IVCOMP 11.2.0.7
Designer 11.2.0.7
Amdt_am_asmuiCommands 1.0
DwgMgr 11.2.0.7
MApiAd 11.2.0.7
Amdt_DesignerCommandsCommands 1.0
Assemblies 11.2.0.7
Amdt_BrowserCommands 1.0
5 REPLIES 5
Must have SP1 installed first, as far as I know...
Dennis Jeffrey, AICE, MICE
260-399-6615
Instructor/Author/Sr. App Engr.
AIP 11SP2, AIP 2008
HP Pavillion Zv5000 (Modified)
Geforce Go 440, Driver: .8185, 2GB RAM
XP Pro SP2, Windows Classic Theme
http://www.design-excellence.com
wrote in message news:5593039@discussion.autodesk.com...
everything.
ACME 11.2.0.7
MCADATTS 11.2.0.7
Attributes 11.2.0.7
GREFACAD 11.2.0.7
CIT 11.2.0.7
MCADCOM 11.2.0.7
MCADAPI 11.2.0.7
MPP 0.0
AutoSurf 11.2.0.7
GREFSURF 11.2.0.7
GrefAd 11.2.0.7
GREFSURF 11.2.0.7
GREFAM 11.2.0.7
GREFDM 11.2.0.7
GREFSYS 11.2.0.7
IVCOMP 11.2.0.7
Designer 11.2.0.7
DwgMgr 11.2.0.7
MApiAd 11.2.0.7
Assemblies 11.2.0.7
I thought the same thing as I was downloading it and then read the readme:
"Service Pack 2 is historical and may be applied to Mechanical Desktop 2007 regardless of whether Service Pack 1, Hotfix 1 or Hotfix 2 has been applied or not. You must have administrative privileges to be able to install Mechanical Desktop 2007 Service Pack 2 on Windows 2000, Windows XP Professional or Windows XP Home."
I even tried installing SP1 then SP2 and still it shows just as hotfix2. Anyone from Autodesk listening?
Mine shows SP2, but I don't think I ever installed the hotfix.
wrote in message news:5594504@discussion.autodesk.com...
If the hotfix was included in SP2, then I'd uninstall it, then do SP2
260-399-6615
AIP 11SP2, AIP 2008
It is a historical patch. I had hotfix 2 installed and then installed SP2.
AMVER reports "Mechanical Desktop(R) 2007 SP2". The 11.2.0.7 values you
are showing from AMVERALL in your other post would indicate that SP2 was
installed because that is the SP2 version info.
Have you tried a reboot?
Mike Dickason
Developer
Manufacturing Solutions Division
Autodesk, Inc.
