This usually indicates that 2 faces are coincident and it can't solve the
intersection. For example, subtracting a 2.00 Dia cylinder from a 2.00 x
2.00 square block, cylinder centered in the block. Where the the curve and
the edge are coincident, you can get this error. Try changing the size of
one feature a small amount, or moving one feature a small amount. Many times
you can get around this by using a different modeling strategy. Without
seeing the model, I can't give you a different strategy.
Robert Davis
QC/CMM Dept.
robert@easmfg.com
E.A.S. Manufacturing Co., Inc.
804 Via Alondra
Camarillo, Ca 93012
805-987-3665 Voice
805-987-7948 Fax
eas@easmfg.com - General E-Mail
www.easmfg.com - Web Site
"ErichBlohm" wrote in message
news:690359.1077260047486.JavaMail.jive@jiveforum1.autodesk.com...
> I am trying to do a boolean intersection on some spheres with grooves in
them. It is a repeating pattern of grooves, so I am arraying the sphere with
the pattern in it around a center.
> I keep on getting: error, inconsistent edge face relationship. What does
this mean and how can I get around it?
> I can't post the part because it is three megs, zipped.
> Thanks,
> eb
