Hi all,
i really really need a fix for this.
I got a part, that was modified in Pro E, and converted to IGES. Problem is, reading it into MDT (2005). It crunches the nubers, then spits out "complete / fatal error - contact Autodesk - restart autocad"
There are only a few posts on the subject, and all seem to date back to 2000 / 2003.
I can open the part up in Inventor, but we haven't switched over to Inventor yet. (So, Do I spend half the day trying to sort out MDT? or do I spend half a day to set up Inventor?)
Did I miss an update? And worse still, MDT 2005 dosen't seem to be supported anymore. As far as i know I have all teh updates (and that wasen't an easy task..)
I can create IGES files, and even the IGES file I created of the part cannot be read back into MDT. I even tried to re-save the IGES file in Inv. Again, MDT won't read it.
And, the same goesd with STEP files. I can create a STEP file in Inv, and then try to import it into MDT. again, crunches the numbers, and spits out "fatal error".
So, it looks like my version of MDT can only read MDT files. it can make IGES & Step files, it just can't read them.
Any and all help is appreciated!
