This is a Registry error. Registry cleaners cause it. You do not have to reinstall autocad 2007. You can if you want but you only have a limited amout of times you can install or reinstall the program. It is better when you get this error to go into c:/programfiles/autocad 2007 and if the folders for the registry backup and open them and merge the backups back to you computer registry
