Are we still the only company in the world that have major problem with MDT 2009. Still this issue when edit sketch and in some files the sketch disapper from the screen and I need to restart the system every 15 minutes. Other problem is when I move a part I need to type regen to see the actual movement or swicth to 2d wireframe or save.
Still xp and al drivers OK.
Now the question should we continue with our 9 subscription when we not using Inventor?
Now I have more problem then ever. I have a new DELL M4500 with W7-64 bit and Nvida software that is developed for this machine. It might be some thing with dual screens, 3d wireframe and spaceball because when i work with my old lapptop M70 and xp 32 bit everything works perfect using only lapptop screen and no spaceball.
So now i work 5 minutes with a model the my sketch disapear and I need to restart. Or i move a part then i need to type REGEN or SAVE to see that the new possition of the part.
I have finally found out the reason for my problems. It’s my balls, not that the space ball. If I don´t touch it everything work joust find, but it’s hard to work without it.
