IMPORTANT. Forum to be archived in several phases. You can no longer submit new questions - but can only answer existing threads until Oct 17th 2016. Please read this message for details
Mechanical Desktop (Read Only)
alochner
141 Views, 2 Replies
FEA 3D help
When I try to run an FEA calculation, I get the error message "Insufficient Supports"
2 REPLIES 2
in reply to: alochner
MDT uses a lot of disk space when doing FEA and it is possible that you are running out mid-process. This is particularly a problem using NT4 because of the small maximum primary partition size. If this is the problem, you can change the temporary file location so that it uses a larger disk partition. Assist - Options - Temporary Drawing File Location.
To be able to make a calculation you need to add supports to the part until
it is "fixed" in space. The supports should simulate the physical supports
the part has when subjected to the applied load, and must constrain the part
in all directions and angles. Se attached jpg for example.
Per Engberg
Roblon Engineering
http://www.roblon.com
