Also, under "Assist"-"Mechanical options"-"Preferences" set Desktop Audit
Control to "always". This continually checks all drawings for errors and
corrects them if possible.
If you keep having problems you should reply with your system specifications
(Processor, RAM, Operating System, Video Card, MDT release & SP #.) While it
may not be due to these factors it helps to determine the
cause.
The current SP for MDT6 is SP4 with assembly.arx updated. Type amver at the
command line to see what version and SP you are using.
Per Engberg
"Kevin Terry" wrote in message
news:41121ee8$1_3@newsprd01...
> start up mdt, and create a new blank drawing. now go to
> file..utilities..recover desktop. that will present a dialog box just like
> file..open, so open these files you listed below. after they open, hit the
> F2 key to read any error messages, and follow any instructions there.
> Kevin
> "Douglas Barr" wrote in message
> news:41110f49$1_2@newsprd01...
> > I have probably been booted out 8 times this morning. Occasionally I
> double
> > click a sketch dimension for a change, it fails there. Occasionally
> there's
> > no editing activity whatsoever, just a scroll zoom.
> > Is this just the nature of MDT? I'm green at it. One month.
> > -doug
> > FATAL ERROR: Unhandled Access Violation Reading 0x0004 Exception at
> > 57b3b42ch
> > 08/04/2004 at 09:38:18.889 Drawing: F:\Sprague\177\177620.dwg
> > 65466013h
> > 08/04/2004 at 11:37:05.421 Drawing: F:\Sprague\177\177827.dwg
> > FATAL ERROR: Unhandled Access Violation Reading 0x419109d7 Exception at
> > 6546a8d7h
> > 08/04/2004 at 12:08:58.921 Drawing: F:\Sprague\177\177840.dwg
> > FATAL ERROR: Unhandled Access Violation Reading 0x0000 Exception at
> > 57a11556h
> > 08/04/2004 at 12:13:25.999 Drawing: F:\Sprague\177\177837.dwg
