IMPORTANT. Forum to be archived in several phases. You can no longer submit new questions - but can only answer existing threads until Oct 17th 2016. Please read this message for details
Show only
Search instead for
I get a fatal when i'm using multiple viewports in MCAD5.
When I gripedit an entity, the moment I select the grip ACAD gives an error. This only happens when I have 2 or more viewports in modelspace. The problem also occurs in Mechanical Desktop 5.
I am using a 2-monitor machine but colleagues also ran into the problem
Hi, I'm facing a similar problem. When trying to create a second viewport on any given file Autocad crashes corrupting the file.. Please, any help will be aprecciated.
