IMPORTANT. Forum to be archived in several phases. You can no longer submit new questions - but can only answer existing threads until Oct 17th 2016. Please read this message for details
Mechanical Desktop (Read Only)
FATAL ERROR: Unhandled e06d7363h Exception at 7d4e2366h
3 REPLIES 3
1019 Views, 3 Replies
Hello I started getting this error today.
When autocad starts it loads the drawing and in abotu 1 second i get the error and it shuts down. Any ideas??
Mechanical Desktop 6 with autocad 2002 running on windows XP 64bit. Has been working fine about 4 weeks. Thanks for your help Tim
3 REPLIES 3
Hola, tengo el mismo problema que tsiegel... Instalˆm el Architectural desktop 2006 en windows xp 64 bits, funcionˆu muy bien durante 4 semanas y luego al intentar abrir un archivo existente (file_open) el programa se cierra indicando el siguiente error: FATAL ERROR: Unhandled e06d7363h Exception at 7d4e2366h
Ya lo desinstalˆm y volvˆq a instalar y el error se repite... por favor necesito ayuda para resolver el problema... Gracias!!!
Free News Reader
http://put.hk
http://put.hk/reader/discussion.autodesk.com/autodesk.mechanicaldesktop.html
arben.allaraj
Maybe you should see this:
http://blog.jtbworld.com/2006/12/autocad-error-aborting-fatal-error.html
I just started getting the same error message. I'm running AutoCAD 2002 on a Windows XP Pro 64-Bit system. This morning Microsoft Update installed several security patches and rebooted the system. The updates that installed this morning are as follows:
Cumulative Security Update for ActiveX Killbits for Windows XP x64 Edition (KB956391)
Security Update for Windows XP x64 Edition (KB956803)
Cumulative Security Update for Internet Explorer 7 for Windows XP x64 Edition (KB956390)
Windows Malicious Software Removal Tool x64 - October 2008 (KB890830)
Security Update for Windows XP x64 Edition (KB957095)
Security Update for Windows XP x64 Edition (KB954211)
Security Update for Windows XP x64 Edition (KB956841)
Not sure if that's what caused the problem or not, but I started seeing the problem after the computer restarted..
If anybody has any ideas, please reply back.
