<swanan> wrote in messageHI
href="news:6076875@discussion.autodesk.com">news:6076875@discussion.autodesk.com...
All To Whom May Concern It I m having problem to install AutoCAD Mechanical
2009 and its show error message "FAILED- FATAL EROR DURING INSTALLATION"
Kindly please on this.. we are need badly this software For your more
information . THis is a brand pc which refer IBM Intellistation M PRO Model No
: M/T 6225-25A S/N : 99R5631 WINXP PRO SP3 32 bit I m able to installled
INVENTOR but than mechanical doesnt continue its seems some error on windows
or hardware . and for your information.. i m using another pc which using DVD
rom and i m shared the pc with this IBM machine and install. It is anything
wrong while sharing with other pc ... Kindly please advise on this Thank you
Regards Sarawanan cc: sarawanan@vxscorp.com
"Roger Mollon (Autodesk)" <
href="mailto:roger.mollon@autodesk.com">roger.mollon@autodesk.com>
wrote in message
href="news:6077305@discussion.autodesk.com">news:6077305@discussion.autodesk.com...
Sarawanan,
You should post this message in the
"autodesk.autocadmechanical" discussion group, you'll get more help
there.
Roger Mollon
MSD - Novi
Autodesk, Inc.
No : M/T 6225-25A S/N : 99R5631 WINXP PRO SP3 32 bit I m able to installled
DVD rom and i m shared the pc with this IBM machine and install. It is
anything wrong while sharing with other pc ... Kindly please advise on this
Thank you Regards Sarawanan cc: sarawanan@vxscorp.com
"Jason Rhymes" <@> wrote in message
href="news:6077333@discussion.autodesk.com">news:6077333@discussion.autodesk.com...
Roger, While you're on the line, when I download MDT 2009 64
bit (disk 2) from the website, it gets to 99% and gives me a fatal error
every time. Tried downloading it 3 times now with the same result.
Jason Rhymes
3D Solid
Power Toys
including Multi Solid Stretch
href="http://www.acadianagraphics.com">http://www.acadianagraphics.com
wrote in message
Sarawanan,
there.
Roger Mollon
MSD - Novi
Autodesk, Inc.
Mechanical 2009 and its show error message "FAILED- FATAL EROR DURING
INSTALLATION" Kindly please on this.. we are need badly this software For
your more information . THis is a brand pc which refer IBM Intellistation
M PRO Model No : M/T 6225-25A S/N : 99R5631 WINXP PRO SP3 32 bit I m able
to installled INVENTOR but than mechanical doesnt continue its seems some
error on windows or hardware . and for your information.. i m using
another pc which using DVD rom and i m shared the pc with this IBM machine
and install. It is anything wrong while sharing with other pc ... Kindly
please advise on this Thank you Regards Sarawanan cc:
"sjbosley" wrote in messageHi
href="news:6077815@discussion.autodesk.com">news:6077815@discussion.autodesk.com...
Jason The download site is up and running - I just tested it on my home PC and
was able to download the file in ~30 minutes. Did you use the download
manager. This makes a big difference to the download experience. I've attached
an image showing what I see onscreen at end of download. Are you seeing the
same thing? If you are still having problems please send me your contact
information to simon.bosley@autodesk.com and we'll investigate further. Simon
