IMPORTANT. Forum to be archived in several phases. You can no longer submit new questions - but can only answer existing threads until Oct 17th 2016. Please read this message for details
Mechanical Desktop (Read Only)
Fatal Eror during installation of AUTOCAD mechanical 2009
6 REPLIES 6
408 Views, 6 Replies
HI All
To Whom May Concern It
I m having problem to install AutoCAD Mechanical 2009 and its show error message "FAILED- FATAL EROR DURING
INSTALLATION"
Kindly please on this.. we are need badly this software
For your more information . THis is a brand pc which refer
IBM Intellistation M PRO
Model No : M/T 6225-25A
S/N : 99R5631
WINXP PRO SP3 32 bit
I m able to installled INVENTOR but than mechanical doesnt continue its seems some error on windows or
hardware . and for your information.. i m using another pc which using DVD rom and i m shared the pc with this IBM machine
and install. It is anything wrong while sharing with other pc ...
Kindly please advise on this
Thank you
Regards
Sarawanan
cc: sarawanan@vxscorp.com
6 REPLIES 6
Sarawanan,
You should post this message in the
"autodesk.autocadmechanical" discussion group, you'll get more help
there.
Roger Mollon
MSD - Novi
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
HI
All To Whom May Concern It I m having problem to install AutoCAD Mechanical
2009 and its show error message "FAILED- FATAL EROR DURING INSTALLATION"
Kindly please on this.. we are need badly this software For your more
information . THis is a brand pc which refer IBM Intellistation M PRO Model No
: M/T 6225-25A S/N : 99R5631 WINXP PRO SP3 32 bit I m able to installled
or hardware . and for your information.. i m using another pc which using DVD
rom and i m shared the pc with this IBM machine and install. It is anything
wrong while sharing with other pc ... Kindly please advise on this Thank you
Regards Sarawanan cc: sarawanan@vxscorp.com
Roger, While you're on the line, when I download MDT 2009 64 bit (disk
2) from the website, it gets to 99% and gives me a fatal error every time. Tried
downloading it 3 times now with the same result.
Jason Rhymes
3D Solid Power Toys
including Multi Solid
Stretch
href="http://www.acadianagraphics.com">http://www.acadianagraphics.com
Sarawanan,
there.
Roger Mollon
MSD - Novi
HI
No : M/T 6225-25A S/N : 99R5631 WINXP PRO SP3 32 bit I m able to installled
DVD rom and i m shared the pc with this IBM machine and install. It is
anything wrong while sharing with other pc ... Kindly please advise on this
Thank you Regards Sarawanan cc: sarawanan@vxscorp.com
Jason,
I'll pass this on to the folks responsible
for website downloads, thanks for pointing out the problem.
Roger Mollon
MSD - Novi
bit (disk 2) from the website, it gets to 99% and gives me a fatal error
every time. Tried downloading it 3 times now with the same result.
Jason Rhymes
3D Solid
Power Toys
including Multi Solid Stretch
Sarawanan,
there.
Roger Mollon
MSD - Novi
HI
INSTALLATION" Kindly please on this.. we are need badly this software For
your more information . THis is a brand pc which refer IBM Intellistation
M PRO Model No : M/T 6225-25A S/N : 99R5631 WINXP PRO SP3 32 bit I m able
error on windows or hardware . and for your information.. i m using
and install. It is anything wrong while sharing with other pc ... Kindly
please advise on this Thank you Regards Sarawanan cc:
sjbosley
Hi Jason
The download site is up and running - I just tested it on my home PC and was able to download the file in ~30 minutes.
Did you use the download manager. This makes a big difference to the download experience. I've attached an image showing what I see onscreen at end of download. Are you seeing the same thing?
If you are still having problems please send me your contact information to simon.bosley@autodesk.com and we'll investigate further.
Simon
Okay, thanks Simon. Yes, I was using the download manager. That is were the
fatal error was showing up. I'll try and download again tonight and will let you
know if I have any problems.
Jason Rhymes
3D Solid Power Toys
Stretch
Hi
Jason The download site is up and running - I just tested it on my home PC and
was able to download the file in ~30 minutes. Did you use the download
same thing? If you are still having problems please send me your contact
information to simon.bosley@autodesk.com and we'll investigate further. Simon
Nope, same error. (see attached)
Jason Rhymes
3D Solid Power Toys
Stretch
Hi
