i everybody, I need help converting my AutoCad (.dwg) file to a format that my production company can use (only .iges) and there is no software that I can find that will do so, and tomorrow I'll have to present my work. I would really appreciate your help, thanks in advance.
I opened your file in AutoCAD 2012 and typed IGESOUT at the command line. Attached is the result. I hope this helps.
@biancaguiso wrote:...there is no software that I can find that will do so,
Free Inventor Fusion http://labs.autodesk.com
Would you be kind enough to convert my dwg to IGS too?
