Mechanical Desktop
Mechanical Desktop
Active Member
0 Kudos
Post 1 of 2
Does Vault Professional 2012 Works with Autodesk Mechanical Desktop?
298 Views, 1 Replies
07-26-2011 05:14 AM
Since MDT last release is 2009, is posible to work with the latest Vault version (2012)?. We want to implement Vault in the company and migrate to Inventor, depending on the MDT integration with Vault will influence the Process, for example: migrating first all MDT files, work with Inventor and later implement Vault, however, will be a longer time frame.
Does someone has migrated from MDT to Inventor and Vault recently?
Employee
21 Kudos
Post 2 of 2
Re: Does Vault Professional 2012 Works with Autodesk Mechanical Desktop?
07-26-2011 12:24 PM in reply to: fmendizabal
One solution is to use the Auto-loader application that is installed with Vault to load the MDT files.
Then download as needed to migrate the files to Inventor.
This will allow to have a single source for data as you transition.
Mikel Martin
User Experience Architect
PLM / Data Management
Manufacturing Community
