I think it is used to reattach dims that have lost there starting and ending
points on geometry. I think in ACAD 2002 the dim assoc setting was enhanced
to allow for dims to update if the Circle diameter was changed using a grip
edit or a property change. But in the case where TRIM or EXTEND where used
to modify a line the dimensions may not find the connection point, so
REASSOCIATE would allow you to re pick your start and end points as needed.
"Al"
wrote in message
news:406c2b72$1_1@newsprd01...
> Hi.
> Can anyone explain DIMREASSOCIATE?
> I was trying DIMREASSOCIATE exploded orphan grouped dims in paper space, -
> it did not work.
> Regards
> Alex
