IMPORTANT. Forum to be archived in several phases. You can no longer submit new questions - but can only answer existing threads until Oct 17th 2016. Please read this message for details
Mechanical Desktop (Read Only)
546 Views, 1 Reply
desktop 2009
Saving a dwg file.  Having problems finding the saved file where indicated by options, "c, users, appdata, temp" is where it is supposed to be.  No recent saves show up as either .sv$m , .ac,  or temp.
Can anyone help?
1 REPLY 1
TravisNave
Try posting to this forum:
http://forums.autodesk.com/t5/Autodesk-Mechanical-Desktop/bd-p/89
Although, shouldn't you know where you are saving your files by default?
Autodesk Forums:
