Announcements
IMPORTANT. Forum to be archived in several phases. You can no longer submit new questions - but can only answer existing threads until Oct 17th 2016. Please read this message for details
Mechanical Desktop (Read Only)
236 Views, 1 Reply
Corrupt BOM
Good morning,
I'm using MDT 2009 sp2 on windows xp professional 2002 sp3.
I have an assembly file which is made up of both local and external sub-assemblies.
I start a new file in which I want to make drawings of the assembly with scenes etc.
I catalog in the file, make a new bom and expand it as I like. My problem is when I re-open my new file the bom is corrupt, as in does not remain the same as when I left it, will not collapse or expand as it should etc... making it impossible to balloon my drawings correctly.
I have tried to reproduce the problem with subs within the assembly and cannot. it is isolated to the one assembly file. I have audit set to always, and have tried recover and audit on all files involved.
My goal is to keep file sizes down by not having too many layouts/drawing views in one file, but all drawings driven from the same assembly.
Has anyone had similar issues?
Thank you.
1 REPLY 1
Use AMRECOVER on the assembly and all its
external files until no more errors are reported in the text window and
delete all BOMS. Purge all files. Make a  BOM only in the drawing
file. Note that the structure of the databases in all files need to lign up to
get the wanted result in the partlist/balloon option.
Good
morning, I'm using MDT 2009 sp2 on windows xp professional 2002 sp3. I have an
assembly file which is made up of both local and external sub-assemblies. I
etc. I catalog in the file, make a new bom and expand it as I like. My problem
it impossible to balloon my drawings correctly. I have tried to reproduce the
all files involved. My goal is to keep file sizes down by not having too many
assembly. Has anyone had similar issues? Thank you.
