Teodor,
This is a known issue with the Today window. The only way to eliminate this
problem is to turn off the Today window by setting the sysvar STARTUPTODAY
=0.
Mike Dickason
Developer
Autodesk Mechanical Group
"Teodor Boiesan" wrote in message
news:2F2F82BAF0ECE8EE29FCF17988AFBE6A@in.WebX.maYIadrTaRb...
> Could be a setup problem on my computer or..
> Every time when I start MDT6 or Acad2002 a second window opens (AutoCAD
2002
> today) and if I choose Browse to open an existing drawing, make some
changes
> to it and then,(after saving or not those changes) I decide to close
AutoCAD
> window , A warning dialog appears : ! AutoCAD cannot close Drawing1.dwg,
> because there is a command still active. Please complete the command and
try
> again.
> Switching to drawing1.dwg ( default opening drawing at the beginning of
> AutoCAD session ) shows the Command: prompt
> I have to press to cancel some command before I can close the
window.
> This is just an extra step but I would like to know if it can be
eliminated.
> Thanks,
> Teodor Boiesan
> Design Engineer
