IMPORTANT. Forum to be archived in several phases. You can no longer submit new questions - but can only answer existing threads until Oct 17th 2016. Please read this message for details
Mechanical Desktop (Read Only)
Message 1 of 10
CLKallies
682 Views, 9 Replies
blocks -
inserting wblocks - inserts in as a thin line not as it was made
9 REPLIES 9
Message 2 of 10
Hi
Can you switch on line weight and check the issue?
command lwdisplay>>ON
Sridhar Subramani
Senior Product Owner
Message 3 of 10
saved 2009 DGW's as 2012... in addition to having problems with "blocks"  it appears that when i draw let say a circle outside of the drwaing boarder it has no "y" ... it also appears to be a flat line... also, some areas outside of the boarder i'm unable to draw anything... no lines or object... HELP... confused old man... what happened to Ver 2.5...lol...
i attempted lwdisplay.. no success
Message 4 of 10
Can you please attach a sample 2009 file and expected results to see in 2012.  I would appreciate if you could send few steps to reproduce the issue in 2012.
Sridhar Subramani
Message 5 of 10
i did attpmt this last time however the file was to big
Message 6 of 10
If the file size is less than 15 mb, you may attach the file at sridharDOTsubramaniATautodeskDOTcom or upload the file at http://www.megaupload.com/   Please send the link at my E-mail if it is confidential.
Sridhar Subramani
Message 7 of 10
file is only 2mb... but error message states it's too large
Message 8 of 10
Please send the file by E-mail
Sridhar Subramani
Message 9 of 10
i tried to email to addresses sent but our system has blocked... i will have to obtain permission unless you have another email addressSmiley Happy
Message 10 of 10
Thank you for attaching the file.
I could reproduce the issue.  This is happening because of UCS orientation.  The UCS is rotated about x axis by 90 degree.  Hence, the blocks are seen as lines.
To fix the issue; command UCS>>View  (enter view option)  Now the ucs will be oriented in the viewing direction.
The out of limits message is because, limits is set to ON.  This means, you cannot draw anything outside of maximum limits you have set in the drawing.  To fix this issue, command limits>>OFF
Hope this helps
In the future, please post similar issues on AutoCAD Mechanical news group.
http://forums.autodesk.com/t5/AutoCAD-Mechanical/ct-p/2002
Sridhar Subramani
