The "Assembly Modelling"-button sometimes stops working for
no apparent reason. Editing the button properties (RMB on any toolbar,
choose Customize, select tab "Properties" and then click on the button you
want to edit) by removing the ; at the end of ^C^Camdt_assm_modeling;
will restore function. The strange thing is that if you then add it again it
still works!
Per Engberg (MDT6PPsp4+arg)
wrote in message news:4884060@discussion.autodesk.com...
My assembly toolbar just vanished - I have tried using menuload and menu
commands, customize, etc every Command I can think of to get it back - there
is always a blank column where it belongs under the main when you click the
assembly icon. It seems to be in the AMDTPP.MNS file - I just cannot make it
appear - turn the checkmark on and off in the command assignment window but
it just will not come back. Any suggestions what I might do?
eg
