IMPORTANT. Forum to be archived in several phases. You can no longer submit new questions - but can only answer existing threads until Oct 17th 2016. Please read this message for details
Mechanical Desktop (Read Only)
egalicki
193 Views, 1 Reply
assembly toolbar
My assembly toolbar just vanished - I have tried using menuload and menu commands, customize, etc every Command I can think of to get it back - there is always a blank column where it belongs under the main when you click the assembly icon. It seems to be in the AMDTPP.MNS file - I just cannot make it appear - turn the checkmark on and off in the command assignment window but it just will not come back. Any suggestions what I might do?
eg
1 REPLY 1
in reply to: egalicki
The "Assembly Modelling"-button sometimes stops working for
no apparent reason. Editing the button properties (RMB on any toolbar,
choose Customize, select tab "Properties" and then click on the button you
want to edit) by removing the ; at the end of ^C^Camdt_assm_modeling;
will restore function. The strange thing is that if you then add it again it
still works!
Per Engberg (MDT6PPsp4+arg)
wrote in message news:4884060@discussion.autodesk.com...
eg
