Actually, I had time to fiddle with it. I made a very simple model of bar
elements, 2 for the door and frame and 2 for the gas spring (as a sub) and
was suprised to see that it works well. A global variable drives both the
opening angle and the constrained length of the gas spring. This is may be
over-simplified, the "gas spring" is perpendicular to the hinge axis and it
doesn't go over center.
Good luck with it.
Jeff
Jeff Howard
wrote in message
news:D3DDF49297753456A6FFF464D9A108A5@in.WebX.maYIadrTaRb...
> Nope. If you want the gas spring to follow you will have to model as two
> parts in the same assy as the door and frame.
> It might be possible to use a global variable to drive the length of the
gas
> spring as a function of the angular relationship of the door and frame. I
> doubt it would work reliably, if at all, but if you've got time to
> fiddle....
> Jeff Howard
> jeff4136@mindspring.com
> Patrick Johnson wrote in message
> news:73D759D82308E709D67C92E0935780B0@in.WebX.maYIadrTaRb...
> > I am trying to constrain a gas spring which is treated as a subassembly
> (2)
> > parts to a door and a frame. I have the door constrained through the
> > hinges, which allows me to open the doors thru an angle constraint. I
> would
> > like the gas spring to extend and rotate with the door opening, however
I
> > lose the constraints connecting the two ends. Is it not possible to
have
> a
> > subassembly that will slide in a higher assembly?
> > pat
