I have a problem where dimensions between ex-sketch items such as work points and axes appear in assemblies etc. These dimensions are on the same layer as parametric dimensions in sketches, however sketch dimensions do not appear when you are not editing a sketch.
Is the layer significant for parametric dimensions? Can I put work point dimensions on a separate layer and turn that layer off?
Paul Riley
