IMPORTANT. Forum to be archived in several phases. You can no longer submit new questions - but can only answer existing threads until Oct 17th 2016. Please read this message for details
Show only
Search instead for
When I use the AMRESCALE command, it doesn't just change the scale, it
*moves* them. The dimension line moves closer or farther away from the pick
points depending if the scale was decreased or increased. (Or is this a
"feature"?)
