Anytime the ampoweredit is invoked, it brings up the properties dialog box. For example, if I double click on a block, in the command dialog I see ampoweredit, but then instead of seeing refedit below, I see '_.properties. It doesn't matter if I double click on the block or actually type ampoweredit at the command and then select the block. Either way I see '_.properties. Note: This is just for one users profile, but I can't figure it out for him.
