IMPORTANT. Forum to be archived in several phases. You can no longer submit new questions - but can only answer existing threads until Oct 17th 2016. Please read this message for details
Mechanical Desktop (Read Only)
ampoweredit brings up the properties dialog box.
2 REPLIES 2
shastu
286 Views, 2 Replies
Anytime the ampoweredit is invoked, it brings up the properties dialog box. For example, if I double click on a block, in the command dialog I see ampoweredit, but then instead of seeing refedit below, I see '_.properties. It doesn't matter if I double click on the block or actually type ampoweredit at the command and then select the block. Either way I see '_.properties. Note: This is just for one users profile, but I can't figure it out for him.
2 REPLIES 2
in reply to: shastu
Please provide version of MDT. Double-click function is controlled differently in various versions
Troy Nageotte
Inventor Professional 11 SP3
MDT 2007 SP2
Windows XP SP2
CAD Manager
shastu
in reply to: shastu
MDT2008, and it doesn't matter if the Double-Click function is on or off, it behaves the same.
