IMPORTANT. Forum to be archived in several phases. You can no longer submit new questions - but can only answer existing threads until Oct 17th 2016. Please read this message for details
Mechanical Desktop (Read Only)
2007 File Migration Utility doesn't seem to work
1 REPLY 1
kstate92
753 Views, 1 Reply
I can start the utility, provide it with a list of files, set it to analyze and click run. A dialog box instantly pops up and states Windows cannot find 'acad.exe'. I've ran MDT 2007 and even the Basic version first before running the utility with no different result. And leaving MDT open, the Utility tells me to close MDT first. MDT is part of Inventor Series 11, in case that's a factor. Is there a custom startup switch I need to add to a short cut? Any ideas at all?
XP SP 32bit
Inventor 11 SP4
MDT 2007 SP2
KState92
Inventor Professional 2020
AutoCAD Mechanical 2022.0.1
Windows 10 Pro 64 bit - 1903
Core i7-8700 32 GB Ram
Quadro P2000
1 REPLY 1
Mike--
in reply to: kstate92
i have mdt2009 and the file migration utility dont work, only the file migration utily for mechanical work
