I assigned a jpeg file as texture to a polygon. It displays ok, but when i render using MentalRay getting error : error opening texture file.
can't find what's wrong. Any suggestion most appreciated.
1. I am using MAC OSX 10.6.3
2. The error message is :
// Error: (Mayatomr.Output) : while defining texture "file3:tex": failed to open texture file /Volumes/BigDisk 1/Johan Projects/Autodesk MAYA projects/Boy and Dog/images/DenJoII.jpg
3. The problem : I have no "BigDisk 1", I have a disk labeled "BigDisk". So it seems that MentalRay adds a "1" to the volume name, and then of course can't open the texture file as this volume does not exist.
Can anybody please tell me what is causing this?
thanks.
Second update
______________
getting following error messages :
Maya Fur Renderer: Creating equalizer map for surface 'chevelureShape'
Maya Fur Renderer
// Error: (Mayatomr.Output) : while defining texture "file3:tex": failed to open texture file /Volumes/BigDisk/Johan Projects/Autodesk MAYA projects/Boy and Dog/images/DenJoII.jpg
So, I could get rid of the added "1" in my volume name, but sadly mentalray can't still locate the file. Rendering works with Maya Software and the scene displays ok, it's just mentalray that can't find a file that is there.
________________________________________________________________________
Third update
_____________
In another simple scene : used the 3DPaintTool to paint on a surface. Maya Soft render OK. MentalRay can't open the tif files although the file location and names are correct. I am using two external disk drives. The texture files are on the second external drive. I know that there have been some problems with multiple external disk drives, but this should be solved in OSX 10.6.3.
Fourth update
_____________
Tried the obvious alternative to move the texture file to another location. Moved the jpeg file to my desktop with following result :
// Error: (Mayatomr.Output) : while defining texture "file1:tex": failed to open texture file /Users/johanstalpaert/Desktop/trattoriaII.jpg
Could anyone PLEASE help me out ? Answer : NO
_________________________________________________________________________
Fith update
__________
repalced jpeg/tif with psd file; replaced 2D texture file shader with 2D psd file shader. works ok.
I am under the impression that this forum is just a black hole that absorbs all the problems people encounter and ... never sends anything back.
