Hello All,
I just set off my first batch render with Arnold and everything looks great except for "Arnold" written across the images. I have no idea what I am missing on this one. All other settings came out as I expected so I'm not sure where this watermark feature is coming out of. I attached a png file of one of the renders so you can see what I am talking about.
Any suggestions appreciated. Thank you.
Sincerely,
David S Rodriguez
Solved by Stephen.Blair. Go to Solution.
Hi
Batch rendering requires an Arnold license. Without a license, you get the Arnold watermark.
Maya 2017 includes foreground rendering with Arnold, which means you can use Render Sequence or the Arnold Render View. Those renders won't have a watermark.
See Changes in Rendering for more info.
Stephen
Solid Angle Support
Stephen
Thank you for the clarification. Makes complete sense now. I did figure out it had something to do with the licensing just didn't realize all the details of the merge with 2017.
David S Rodriguez
