Is there a way to set the Intersection Classification (edge/normal) of the MFnMesh booleanOps trough the Maya API like on the polyCBoolOp node. The API boolean operator only has 3 options kUnion/kDifference/kIntersection and that's it.
Janos
Solved by vijaya.prakash. Go to Solution.
Unfortunately no other way. Maya API supports only Union, Difference and Intersection Boolean operations.
