Hi
This hasn't been an issue before, and I've not got the problem with my other hair clumps/splines, but for some reason I can no longer select the splines/guides for one of my hair clumps I've made using XGen. 😕 I have tried loading up the project from my PC to my laptop, but as there were issues, I don't recall ever saving. I've tried selecting/deselecting the camera-based selection mode, but that doesn't make any difference. I can select the splines from the outliner, but I still can't select the vertices. Any ideas what the problem could be or how to fix it...? I'm currently using Maya 2022.
Solved by t_smith5. Go to Solution.
Never mind... This always seems to happen to me as soon as I post about a problem. 🙄😅 Turns out they were locked. Don't recall ever doing that. I did check if they were, but it didn't make any difference. However, once I selected them from the outliner and hit the lock/unlock, that fixed it. Not sure if a mod wants to delete this thread...?
Turns out that isn't quite the solution... I'm getting the same problem again, but no matter what I select, even in the Outliner, unlocking them isn't allowing me to select my splines. 😕
