Maya LT Forum
Welcome to Autodesk’s Maya LT Forums. Share your knowledge, ask questions, and explore popular Maya LT topics.
where has Autodesk hidden the connect joint tool
2 REPLIES 2
ben.calderwood
473 Views, 2 Replies
I have recently started using Maya LT 2015 and whilst creating a skeleton rig I noticed that the Connect Joint tool which used to be under the Skeleton tab has disappeared. I'm trying to create a star shaped skeleton with a central root and then 5-6 bones protuding from it. I've tried using the Insert Joint tool but all that does is add an extra bone in between two existing joints. I also tried linking the bones with "P" but that adds this horrible "transform" node in between the two joints which I don't want. Any ideas?
2 REPLIES 2
in reply to: ben.calderwood
http://knowledge.autodesk.com/support/maya-lt/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/MayaLT...
This reference is saying that it is there but I do not see this available to me either. Could someone please respond to this ?
viviane.rochon
Hi Sebastian,
The Connect Joint, Disconnect Joint and Remove Joints commands have been added in Maya LT 2016 EXT 1.
Viviane
Viviane Rochon Montplaisir
