My Problem is that it wont leave the Cut, Draw Geometry, or Target Weld Modes even after Im done using and pressing "Enter" on my keyboard.... Even starting a new scene it still in these modes....only unless I completely exit and restart the program will it stop
Thank you for posting to The Area Forums.
The issue that you are experiencing seems quite strange. What version of Maya LT is it that you are using? Is it Maya LT 2015? If you are running Maya LT 2015 and have not updated to the latest Service Pack, I would recommend doing that first. The service pack can be found at the following link:
The second thing I would recommend is to reset the Maya LT preferences as sometimes preferences become corrupt and cause issues like the one you are experiencing. Follow the steps in the following link to reset the preferences:
I hope that information is helpful.
Cheers,
" like when I select a Vert to weld it will actually collapse all verts surrounding it as well as any verts from a completely different seperated mesh on a completely different layer"
-- Set your merge components tollerance to something much lower.
"I will try this service pack as I just downloaded it yesterday and started to mess around with it"
-- SP's are good to instal.
"Ive been an avid user of modeling programs for years now and can find my way around bugs and errors but these are quite annoying."
-- Maya takes a little getting used to. Some of the ways it expects things to work can feel wonky comming from other apps. Its natural to feel a touch frustrated at first. Dont worry, it will go away once you "understand" maya. It gets better, I promise you. Took me a while too. I came from Lightwave, Max, Blender etc... Maya was so different at first. now I cant use anything else.
Okay this is getting really ridiculous, the way you guys are handling your business is just insane. I recently purchased yet again another product "Mudbox 2015" and I keep getting an error that tells me that either my computer time is is of or my connection to the servers was closed out.....then i try to manage my license in my Account (Yet another account) that i created and it wont save the changes to my account so that i can fill that ONE seat that I purchased in order to use this program on my computer........ then when I finally install it for the umteenth million time i get the same error......I know that you guys are trying really hard to stop piracy but this is getting really ridiculous that i cant even call someone to get help I have to wait at least 24hours for help and then noone replies.....
For rental issues, the error noted should be solved by the following:
http://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Meta-licensing.html
This is a known issue too. I am glad you solved it.
