I can't seem to find the Optimize UV tool. The icon is a little grid with a checkmark in the corner. I've opened all the UV icon tabs and can't see it. I've used it before and now its just gone.
Solved by edoartworks. Go to Solution.
Here's the screenshot of the UV window.
The Optimize tool I'm refering to.
I have the exact same problem, if you find a fix please let me know. I'm searching for one as we speak.
Seems to only happen for me when I save a file and close down the program, upon reopening it I come up with the missing uv options. If I exit out of the UV editor and reopen it from the UV- UV Editor option the options are magically back.
Check your plugin manager. Search for Unfold3D.mll and see if it's loaded. Then close and reopen the UV editor and it should work!
