Greetings!
I'm new to Maya LT, but it seems to be a great tool so far.
However, while working on a keyframe animation I just couldn't figure out the following:
I have a Character with humanIK. I'm using the conrtol rig and auto key to set up an idle animation. The animation is about 40 frames long and I set the keyframes to be every 10 frames on the whole rig for testing.
Now, if I realize that I need to rotate the hips on the whole animation, so that they face more to the right for instance, how could I do that whithout adjusting every single key?
In 3DS Max's CAT System you could achieve this by simply turning off auto key and rotating the bone. The set keys would adjust their rotation value in relation to it. Is there a way to achieve the same in Maya LT?
Thanks in advance,
Nora
Solved by remimcgill. Go to Solution.
I don't know if i understand your probleme , because i don't know 3ds Max Cat (I am downloading trial).
But , you can turn off Auto key .. And look at Windows/preferences > Settings > Animation and at Blending Animation
Maybe you talk about Animation layer ?
Have a good day
Right now the only way to do this is to edit in the graph editor. In Maya you would use animation layers, but the animation layers feature is not in Maya LT.
