I am trying to do some simple UV editing. When I first create a set of UVs, the viewport shows this simple box with red, green and blue handles where you can drag the UV map and scale it.
HOW DO YOU GET THAT BACK? What is that tool? As soon as I move the camera, the tool is gone and I don't know how to get it back. The cursor shows an arrow with a little square behind it.
Bob
I believe its called the projection manipulator. If you haven't deleted the history on your object, select the object and go to the channel box editor. You can select it under the inputs in your history. It will be called something like polyPlanarProj1.
Also, if you have just clicked in the viewport and lost sight of it, you can do a control+z (or command+z on a mac) to get it back.
