Hi!
I have two problem when I import .mb files from ImageStudio 2008 to Maya.
First, I have only camera: "enviroment:camera (defaultRenderLayer), I can setup up defults views (front, side, top) and I can not rotate it as normally I do with anyone soft, I mean, I rotate move to right but my model goes to left
😕Second, the image that I obtain with IS is not the same the I obtain with Maya MentalRay, as you can see at follows attachs files. There are some bad with the lights I guess but I not sure.
Any help it's will recevied well
Thanks advance.
Regards!
