Hello Forums,
about three weeks ago, maya 2014 started being stuck at the splash screen saying "Maya loading" and doing nothing. I also tried running it with admin permissions, repaired it, uninstalled and deleted Appdata\Local-and-Roaming\Autodesk\, then installed again. I also tried installing Maya 2013, to see if that starts up: it doesn't.
EDIT: I also tried restarting that license program
The only thing I can call a reason is: It randomly asked me to license and stuff, after i accidently opened it twice. Then I 'clicked through' (I did read it though) and killed the second process. After that it stopped working.
So.. how can i fix it?
Thanks in advance =D
By the way: I am new here =P
Also tried using Maya LT, doesn't work either. Also stuck on "Maya LT Loading".
Seems like no Autodesk product is going to work.
Something seems broken.
Also, how do i get a debug log file?
Found out how to run maya in prompt mode, seems to run normally!
Result: untitled mel: _
This is a very bad way of using maya though..
Tried using MatchMover 2014. Got an error. The details are below.
Error module: ig4dev64.dll Error code: c0000005 Error offset: 000000000012b60 OS Version: 6.2.9200.2.0.0.256.48 scheme id: 1031 Additional Info 1: 2411 Additional Info 2: 241146918ba9b0a95819ed6feb848f48 Additional Info 3: 3bb8 Additional Info 4: 3b83126e1377cb74141341d54ba6085
Composite won't even start.
