Recently installed Maya LT 2015. Everytime I launch I get the Account Login Dialogue, which then crashes, and leaves me with the output window, but no ability to do anything.
Anyone else had this?
Solved by avto. Go to Solution.
Based on the error message you receive, it appears that you have Maya LT 2015 rental license. With rental license, you must be a named user to use the product.
Below is the link to a Autodesk KB article how to create a named user.
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
Then please check your Internet Explorer Options > Connections > LAN settings and make sure clear all check boxes there (e.g. Automatically detect settings, Use automatic configuration script and Use a proxy server for you LAN).
http://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Meta-licensing.html
