I'm new to hair systems so I've got this question, is there a way to make my xGen hair a permanent primitive / object / model (however you wanna call it) so I don't have to rely on xGen preview anymore?, basically convert my xGen hair to a separated object.
Solved by pshwayka. Go to Solution.
You can convert your XGen hair to nHair. Note: This method assumes you are done with xGen and don't need it anymore.
Hopefully this is the kind of solution you had in mind...
