Hello. I'm having problems with Maya 2016 Service Pack 6. When i select a mesh, and press Ctrl + D to duplicate, it duplicates with a smooth applied. It turns out that i have a 50% chance of duplicating my Mesh without this smooth applied. Sometimes it comes with a smooth, sometimes it doesnt. This is anoying me because i have to delete the mesh i just duplicated and try again to see if this time its going to work.
And no, i'm not duplicating my mesh with '3' pressed on... i dont know whats happening...
Ok guys, so i think i managed to solve the problem. I just installed Service Pack 1 for Maya 2016, and it seens that everything has been fixed so far. Even when i deleted all history of all objects, some of then got smoothed for no reason, and even deleted! So downloading SP1 so far it seens to solve my problem..
Sorry for double posting here, but i though the problem was gone... Nope.. I installed all of the services packs, and in the beggining everything works fine. After a few moments working on my scene, the problem appears again (Ctrl + D is smoothing my object, deleting history is smoothing my objects aswell). Does someone knows whats happening here? I think i'm going back to Maya 2015...
Hi, I'm getting the same issue. Were you able to find a fix? The only workaround I have is to export my model into a new scene.
I am having the same issue. I have a number of objects in a scene, and many of them are organized in groups. When I select a group and try to duplicate it some of the meshes are becoming smoothed, changed color, and sometimes translated. One mesh smoothed and appeared far from its original position and when I try to select it, I cant. I switched to faces and I was able to select faces but they were invisible and far away even from the smoothed mesh.(one more time in case its confusing- I select an OBJ and duplicate it, a smoothed mesh appears far from the original location, and another invisible mesh is selectable at a different location from the other two).
Once I have the smoothed mesh I select it and press 1 but it does not change. There also seems to have something to do with deleting history? I am not sure if that is true but it seems to happen around the time I delete history.
Hello everyone. Its been a long time since my last post here, but i did managed to solve this. The only way i fixed this problem, was formating my computer. I deleted everything from the HD, and installed Windows 7 Professional again, and instaled Maya 2016 with Service Pack 6 again, and so far i havent seen the problem happening. Actually, a really few times it buged again, with this smooth problem, but i just saved the file, and loaded it again, and the problem was gone.
I dont know why maya 2016 have this issue, but hey, try doing what i did, and see if it works.
