I recently updated to Maya 2016 Extension 2 but can't get it to launch on my main workstation.
It gets as far as opening the Output Window, which is blank, and continuously trying to launch multiple "acwebbrowser.exe" processes.
I have tried uninstalling and re-installing multiple times with no progress. Still fails to load Maya after installation.
I have a network license and have installed on other machines successfully, and can launch it on other machines including render nodes and spare workstation but not on my main working rig.
This is a big problem, especially with deadlines in a few days and projects already started using Maya 2016 Ext 2.
My main rig is Win7 machine. - doesn't work
My spare workstion is Win 7 - works fine.
Renders nodes are all Win 10 - works fine.
Not sure what is going on.
I did get an error during installation where installer failed to write to start menu shortcut item due to incorrect permissions.
But this never happened on any other machine installation.
Help.
Have you tried right-clicking the icon and run as Administrator? Or just login as another test local administrator account?
Update the user privileges to files.
The More Info dialog will display the error generated during the installation process. In the following example Uninstall tool.lnk generated the error message.
Perform the steps below on the folder containing the file.
In the example below the folder is Autodesk, Inc..
The Installer has insufficient privileges to modify the file C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Autodesk\Uninstall tool.lnk
Set the privileges for the folder mentioned in the error message, in our example C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Autodesk\ , following the steps below.
Windows 7:
Thanks for the advice guys.
I had already tried reinstalling as Administrator by right-clicking installer "Run as Administrator" but had no luck with that.
I tried to change the Permissions in Start Menu as suggested, but was denied access to make any changes to permissions until I changed ownership to Administrators. I could then add Full Control permissions, and finally got through the install process error free.
But I still cannot get Maya 2016 Ext 2 to load after this successful install.
It still does the same thing when I try to launch Maya.
Just keeps flashing Windows loading icon on mouse cursor and"acwebbrowser.exe" processes continuously starting and stopping in TaskManager.
The "maya.exe"process never has any CPU load. It just sits there in the list of open processes in TaskManager and never launches the software.
Any other suggestions?
Not sure why this is failing to launch on this machine but runs perfectly on others.
All other successful installations on my other machines were done from same installer files.
first question has it created a default folder (my documents\Maya2016.5\) ??? if so try deleting that folder and then run maya 2016.5
if not create one by coping your old Maya2016 folder and renaming it to Maya2016.5 - run Maya 2016.5 again.
I have also tried uninstalling Extension 2 using the Microsoft Install/Uninstall utility ( https://support.microsoft.com/en-us/kb/2438651 ) and re-installing, without any luck.
Tried to find new installer files but can't find Extension 2 download on Autodesk Virtual Agent.
Also tried updating to Ext2- SP1. Still no luck.
Tried changing the "License.env" file to try launch as Standalone instead of looking for network license, but this didn't change anything either.
Never even gets to splash page when I try to launch Maya.
I'm out of ideas.
2016 version still works fine but I need to use Ext 2 as the project I am working on has been using v2016.5 for production and when I open scenes in v2016 I get errors.
Same problem here.
But i found differences in the system environment variables.
Please check:
right click on -> computer -> properties
-> Advanced system settings
-> environment variables
- system variables
delete the entry MAYA_APP_DIR
restart.
cheers
Thanks for the tip, but I don't see any entry in System Variables for Maya as you suggested.
Only entry in System Variables regarding Autodesk products is "ADSK_CLM_WPAD_PROXY_CHECK" which is set to FALSE.
But I believe that is supposed to be there to stop auto proxy detection by default which can cause problems.
So far my main workstation is still unable to launch 2016 Extension 2.
Hi, I know this post is from quite a white ago but I encountered the same problem for my MAC and accidentally stumbled across how to make it work, so I'll leave it here in case someone else has the same problem.
What I did was:
right click on an existing Maya file -> open with -> Maya (Maya 2016.5)
It'll then ask you to input a serial number and product key (my licence for Autodesk Maya 2016 worked)
and voila! Extension 2 should work fine!
Hi all,
I have a solution, we go to C:\User\"username"\Autodesk\maya\
and then you will see the maya 2016.5, delete this folder.
You go to task manager by administrator, you have to end task all process of Autodesk.
Start the Maya 2016 extension 2, the software will create the new folder, and the Maya will start normally.
Good luck, if you need more information, please reply in this topic.
