Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Maya 2015 Linux trial/student version?
17 REPLIES 17
Message 1 of 18
erlogproductions
10701 Views, 17 Replies
I have just a simple question about Maya 2015. Is it possible to get a trial license for Linux? Or is it possible to get a student license for Linux? I am really interested in trying it out in Linux. I am a member of the educational community, so I have the requirements for a student version.
Thanks in advanced.
17 REPLIES 17
Message 2 of 18
http://forums.autodesk.com/t5/Installation-Hardware-OS/Maya-for-Linux/td-p/5015172
And the link in the 3rd post of that thread as well.
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
Message 3 of 18
xdaimon
in reply to: erlogproductions
So the education community does not support Linux versions of Maya.. Ok.. So what about the damned trial versions for linux users who may want to try maya out?
Message 4 of 18
legrand.simon
in reply to: xdaimon
Hey man, the Linux version of maya that you can download in the support section will install just fine. Then use an OSX or Windows generated serial from the education community. This works fine.
Message 5 of 18
Hello legrand.simon,
Thanks for your help! I'm having trouble finding the linux version in the support page. I just seem to find the service packs and license servers. Please help!
Thanks!!
Message 6 of 18
The service packs are the full installers.
http://knowledge.autodesk.com/support/maya/downloads/caas/downloads/content/autodesk-maya-2015-servi...
this is what you'll want to download.
Simon Legrand
http://slegrand.blogspot.com/
Message 7 of 18
xdaimon
in reply to: legrand.simon
Yeah I ended up finding in the Maya documentation that the Service Packs were the actual full installers... I was able successfully install on Gentoo using the rpm command and only a few configuration tweaks.
Thanks. It would be nice though if Linux was included in the downloads dropdown boxes on the main site, even if a notice was clear and plain that said "Linux version not officially supported"
Message 8 of 18
erlogproductions
Hello all,
I successfully installed Maya 2015 student version in CentOS 64-bit. I am running CentOS on Vmware Workstation on Windows 7.
Message 9 of 18
For me that worked up until a couple days ago - Sept 29 2015, when all of a sudden Maya just started to hang indefinitely on startup everytime.  I tried doing a complete uninstall and then reinstalling to newest version - 2015 SP4, same thing.  Running it with gdb produces the following backtrace, looks like the hang has something todo with the licence manager no longer getting a packet...
#0  0x00007fffe637c9a0 in nanosleep () from /lib/x86_64-linux-gnu/libc.so.6
#1  0x00007fffe63adfe4 in usleep () from /lib/x86_64-linux-gnu/libc.so.6
#2  0x00007fffebd66f38 in LMUPipeSession::waitForPacket(LMUPipePacket*, long) () from /usr/autodesk/maya2015-x64/lib/libadlmint.so.9
#3  0x00007fffebd615c5 in LMUPipeConduit::send(LMUPipePacket*, LMUPipePacket*, long) () from /usr/autodesk/maya2015-x64/lib/libadlmint.so.9
#4  0x00007fffebd5e5bb in LMUPipeNamedConduit::send(LMUPipePacket*, LMUPipePacket*, long) () from /usr/autodesk/maya2015-x64/lib/libadlmint.so.9
#5  0x00007fffebd60d7d in LMUPipeConduit::close(bool, bool, bool) () from /usr/autodesk/maya2015-x64/lib/libadlmint.so.9
#6  0x00007fffebd5e2da in LMUPipeNamedConduit::close(bool, bool, bool) () from /usr/autodesk/maya2015-x64/lib/libadlmint.so.9
#7  0x00007fffebd6010e in LMUPipeNamedConduit::~LMUPipeNamedConduit() () from /usr/autodesk/maya2015-x64/lib/libadlmint.so.9
#8  0x00007fffebd5fc13 in LMUPipeNamedConduit::connect(TStr const&, TStr const&, long) () from /usr/autodesk/maya2015-x64/lib/libadlmint.so.9
#9  0x00007fffebc6e076 in AdlmIntUtil::getLMUPipeConduit() () from /usr/autodesk/maya2015-x64/lib/libadlmint.so.9
#10 0x00007fffebc8cd9e in CAdlmIntSATSLicense::validateAndActivateLicense(adlmLICENSEINFO*, AdlmAct::LicenseStateSource&, bool) ()
#11 0x00007fffebc8ef04 in CAdlmIntSATSLicense::checkoutLicense(adlmPRODKEY const*, adlmPRODKEY const*, adlmBOOLEAN, adlmLICENSEINFO*) ()
#12 0x00007fffebc9d424 in CAdlmIntSATSSessionHandle::checkoutLicense(void*, adlmPRODKEY const*, adlmPRODKEY const*, adlmBOOLEAN, adlmLICENSEINFO*) ()
#13 0x00007fffebc92bcc in CAdlmIntLicenseMgr::checkoutLicense(void*, adlmPRODKEY const*, adlmPRODKEY const*, adlmBOOLEAN, adlmLICENSEINFO*) ()
#14 0x00007fffebc6bd1f in impoflldadtleonys () from /usr/autodesk/maya2015-x64/lib/libadlmint.so.9
#15 0x00007ffff675045f in madlm_product_request () from /usr/autodesk/maya2015-x64/lib/libFoundation.so
#16 0x00007ffff674c2e2 in kLatMotionSprite () from /usr/autodesk/maya2015-x64/lib/libFoundation.so
#17 0x000000000040dfe3 in appmain() ()
#18 0x0000000000420831 in main ()
Message 10 of 18
I have tried to install it in CentOS 7, but when I try to run it it won't open. I used my student license when installing it.
Message 11 of 18
warnold1
For CentOS 7, if it's complaining about libtiff.so.3 you will need to install the package compat-libtiff3
Wayne Arnold
Developer
Message 12 of 18
I tried reinstalling CentOS 7 and Maya 2015 with the latest Service Pack. When I try to run it as root it hangs for ever. Even the cursor in the terminal stopped flashing.
Message 13 of 18
xdaimon
what version of xorg d u have? can u check log files under /var/log?
Message 14 of 18
tedlogan888
what output do you get when you run gdb?
just in case...
maya -d gdb
then once you're sure it's hung: ctrl c
then once gdb prompts you type: bt
and hit enter
Message 15 of 18
Thanks for your help! I got it up and running again! I tried again running the maya command as root and it worked.
It would be great for Maya to also run in Linux Ubuntu!! Smiley Happy
Message 16 of 18
warnold1
Maya should run on Ubuntu.  its not a native install, there are install scripts on the web to convert the rpm packages using alien and the required setup changes due to the different system.
Maya shouldn't need to run as root.   should be installed as root, but run as normal user.    that you need to run as root would suggest a file permission error at some level
Wayne Arnold
Developer
Message 17 of 18
Did you run ./setup or rpm to install it?
Message 18 of 18
I used ./setup
