2014/4/15:20:01:44 Stefano STEFANO === Setup started on STEFANO by Stefano ===
2014/4/15:20:01:44 Stefano STEFANO Path_Length: 143
2014/4/15:20:01:44 Stefano STEFANO Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/4/15:20:01:44 Stefano STEFANO Launch
2014/4/15:20:01:44 Stefano STEFANO CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-22149207 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/4/15:20:01:44 Stefano STEFANO Current Directory C:\Users\Stefano\AppData\Local\Temp\_AI4F9B.tmp
2014/4/15:20:02:48 Stefano STEFANO === Setup ended ===
2014/4/15:20:01:45 Stefano STEFANO === Setup started on STEFANO by Stefano ===
2014/4/15:20:01:45 Stefano STEFANO Path_Length: 143
2014/4/15:20:01:45 Stefano STEFANO Current Directory C:\Users\Stefano\AppData\Local\Temp\_AI4F9B.tmp
2014/4/15:20:01:45 Stefano STEFANO Launch
2014/4/15:20:01:45 Stefano STEFANO Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/4/15:20:02:48 Stefano STEFANO Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/4/15:20:02:48 Stefano STEFANO PageOpen LaunchDialog
2014/4/15:20:03:58 Stefano STEFANO PageOpen LicenseDialog
2014/4/15:20:03:58 Stefano STEFANO PageOpen ProductInfoDialog
2014/4/15:20:03:58 Stefano STEFANO PageOpen ProductSelectionDialog2
2014/4/15:20:04:01 Stefano STEFANO PageOpen FullProgressDialog
2014/4/15:20:04:02 Stefano STEFANO Download Play VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/4/15:20:04:04 Stefano STEFANO Download User Pause VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/4/15:20:04:04 Stefano STEFANO Download Paused VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/4/15:20:05:08 Stefano STEFANO Download User Resume VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/4/15:20:05:31 Stefano STEFANO Download User Pause VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/4/15:20:05:31 Stefano STEFANO Download Paused VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/4/15:20:06:00 Stefano STEFANO Download User Resume VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/4/15:20:06:02 Stefano STEFANO Download Complete VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/4/15:20:06:02 Stefano STEFANO Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/4/15:20:06:04 Stefano STEFANO Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/4/15:20:06:04 Stefano STEFANO Download Play VCREDIST2012X64 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/4/15:20:07:04 Stefano STEFANO Download Complete VCREDIST2012X64 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/4/15:20:07:04 Stefano STEFANO Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/4/15:20:07:06 Stefano STEFANO Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/4/15:20:07:07 Stefano STEFANO Download Play DIRECTX http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/DIRECTX.tar...
2014/4/15:20:07:47 Stefano STEFANO Download Complete DIRECTX http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/DIRECTX.tar...
2014/4/15:20:07:47 Stefano STEFANO Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/4/15:20:07:50 Stefano STEFANO Install DirectX® Runtime Succeeded
2014/4/15:20:07:50 Stefano STEFANO Download Play MAYA http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/MAYA_en-US....
2014/4/15:20:27:53 Stefano STEFANO Download Aborted MAYA http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/MAYA_en-US....
2014/4/15:20:27:53 Stefano STEFANO Install Autodesk® Maya® 2015 Failed Download Failed, Installation aborted, Result=1603
2014/4/15:20:27:54 Stefano STEFANO Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/4/15:20:27:54 Stefano STEFANO Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2014/4/15:20:27:54 Stefano STEFANO Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2014/4/15:20:27:55 Stefano STEFANO PageOpen InstallCompleteDialog
2014/4/15:20:33:38 Stefano STEFANO === Setup ended ===
Hi I m an italian student and im learning to use maya but i have a problem during the installation.
Hopefully you got this fixed by this time, but in case anyone else comes across this thread like I did, I was receiving this same error and the cause was one of the .NET 4.0 KB patches failing. I tried installing that directly from MS and it gave me an error with the standalone installer as well.
The solution was to use the uninstall option for .NET framework in the installed programs, and then choosing to repair the installation. It took a minute to repair, and after a restart, I was able to install without any trouble. Hopefully that helps anyone else that might be running into this same issue with that specific error: Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
how do you uninstall .net framework an repair it? I am having same problem
