Area :: Header
New tools, templates and workflows
Announcing Extension 2 for 3ds Max 2015 and 3ds Max Design 2015
Discussion Groups
Maya General
New Member
0 Kudos
Maya 2014 not opening it's own MB files
502 Views, 0 Replies
11-14-2013 08:30 AM
For some reason my installation of M2014 will not open about 85% of the mb files I have made with it.  Each time I try I get several errors and the scene does not open.
doOpenFile ("D:/Users/GMan/Documents/maya/projects/default/scenes/new_g_door_test.mb");
file -f -options "v=0;"  -typ "mayaBinary" -o "D:/Users/GMan/Documents/maya/projects/default/scenes/new_g_door_test.mb";addRecentFile("D:/Users/GMan/Documents/maya/projects/default/scenes/new_g_door_test.mb", "mayaBinary");
// File read in 0 seconds.
// Warning: line 116: The renderer ('base_OpenGL_Renderer') is not a registered renderer. Renderer will not be set. //
// Warning: line 316: The renderer ('base_OpenGL_Renderer') is not a registered renderer. Renderer will not be set. //
// Warning: line 516: The renderer ('base_OpenGL_Renderer') is not a registered renderer. Renderer will not be set. //
// Error: file: F:/Program Files/Autodesk/Maya2014/scripts/paintEffects/dynPaintPanel.mel line 93: No object matches name: strokeGlobals.wrapH //
// Error: line 1675: scriptedPanel: Object 'Stereo' not found. //
commandPort -securityWarning -name commandportDefault;
// Error: line 1: Could not open command port commandportDefault because that name is in use. //
// AbcImport v1.0 using Alembic 1.1.2 (built Oct 22 2012 17:06:34)
// AbcExport v1.0 using Alembic 1.1.2 (built Oct 22 2012 17:06:34)
// Error: line 1: Cannot find procedure "rebuildShowMenu". //
updateRendererUI;
 I will attach the mb file.
