Hey, I've come across a problem with the new Maya 2011, I'm using the student/educational version, and the problem I've found, is that when I try to hide the program using the dock, or via using the Maya - Hide menu, the program does not hide, unless you click hide again by right clicking on the Maya icon within the dock. Along with this issue, there is another probably related problem, whereby the Maya windows will go over the top of other windows that are in use (such as Firefox), when they should sit behind. (For example, if I click from Maya to Firefox, windows such as the Graph Editor & Outliner will still sit on top of Firefox.
Are there any cures for this issue?
Also, one other very, very annoying problem with the educational version is the fact the Educational version message appears EVERY single time you save, this wouldn't be so much much of a problem if the message didn't appear up to 5+ times when you save the once. I'm guessing this happens where I've got referenced scenes/objects and so on in one scene file. PLEASE sort out and get rid of this ridiculous and pointless window, there is no need for it to be there at all. I know I'm using the educational version, I don't need to be told every time I want to save.
