Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Help! Maya 2015 fatal error (Smooth quality display setting)
16 REPLIES 16
Message 1 of 17
3075 Views, 16 Replies
Hey,
A few days before, i installed Maya 2015. First everything worked well, but yesterday Maya started to crash when i try to smooth shade my object. (Smooth quality display setting / hotkey: 3) I tried to reinstall Maya and many other things, however it still crashes.
plz help me. I'm so desperate.
Thx
16 REPLIES 16
Message 2 of 17
pshwayka
Message 3 of 17
in reply to: pshwayka
I tried that... but it's still crashing 😞 Any other tip? But thanks for the fast answer anyway 😉
Message 4 of 17
Hi!
Have u managed to solve that problem? The same thing his happening to me, idk what to do anymore..:/
Message 5 of 17
Maya 2015 may crash turning on Smooth Mesh Preview (3 key) for some meshes if the Subdivision Method is OpenSubdiv.
To avoid the crash either delete or rename the UV Set named ‘map11’, or change the Subdivision Method to Maya Catmull-Clark.
1. Select the mesh
2. Open the UV Set Editor. Create UV’s ->UV Set Editor
3. Select  the UV Set named “map11”
4. Delete or Rename
or
1. Select the mesh
2. Open the Attribute Editor for the mesh shape.
3. In the Smooth Mesh attributes change Subdivision Method to Maya Catmull-Clark
Thanks to QA for the tip on this!
Cheers!
Message 6 of 17
thank you so much!
 i was facing the same problem for long time, and now  i follow ur suggestion,
and the error goes away.
Message 7 of 17
hsource
I just got back into 3D been out of it for some years. I got the same problem and non of these tips have helped.
Any other recommendations?
Very frustrating, simple geometry crashing program when basic smoothing.
pHgabPu
Message 8 of 17
mspeer
in reply to: hsource
Hi!
Please upload a scene-file containing the object.
Message 9 of 17
hsource
in reply to: mspeer
does not accept my rar file (120k) does it need to be uncompressed file?
Message 10 of 17
hsource
Uncompressed file
Message 11 of 17
hsource
I installed service pack 4 and so far no longer crashing.
Message 12 of 17
mspeer
Hi!
Glad it works with an updated version of Maya.
I checked the file and 3 of your objects (like Blades) have a second corrupted UV Set, which very likely caused the problem.
Correct the UV's or delete the corrupted UV Sets ("map11").
Message 13 of 17
hsource
in reply to: mspeer
Thanks! Will do 🙂
Edit UVs > Delete UVs
Is this all it takes? I selected all blades and hit Delete UVs.
Message 14 of 17
mspeer
Hi!
1. Delete UV Sets, not UV's. The easiest way is to use UV -> UV Set Editor.
2. Only one blade needs to be selected (they are instances).
3. Do this for the other 2 objects in the scene too that have "map11".
Message 15 of 17
hsource
in reply to: mspeer
Ok so
Create UVs > UV set editor
I deleted the "Map11", so do that with all objects in the scene? The new elements I created some also have Map11.
What is Map11?
Thanks!
Message 16 of 17
mspeer
Hi!
It's a UV Set you created at some time, maybe by using modeling or UV tools.
Please read the Maya Online Help / Documentation for more details about what a UV Set is.
Message 17 of 17
hsource
in reply to: mspeer
I have not done any UV mapping yet, just basic box modelling right now with defaults.
Thanks!
